fred d
I had a 3HP motor running a Quincy 216 compressor My dad had it when I was a kid and my best guess is that it’s close to 50 years old.
I went out one day and the compressor was not up to its normal pressure. Started to look at things and saw some black soot at the bottom of the base of the motor fins, and figure the motor head finally went out after a very long life.
Purchased a new motor installed it and it came on and ran great.
Went to use it today and realize that the compressor at 70 psi The pump seems to go into a bind if you will, and won’t continue to roll and the motor is acting like it is overloaded.
Turned off the breaker checked it out, pulled a relief valve to bleed off a little pressure at the top of the tank then tried to start it again and got about two revolutions before it stalled again.
After just dumping a bunch of money for a new motor I’d really hate to have to dump an equal amount for a pump.
But I need a compressor.
Below are a couple of pictures. Any help would be truly be appreciated
