I just finished hooking up my compressor. Its a Porter Cable 175 PSI, 2-Stage, 80 Gallon unit. While testing it out I noticed that the gasket between the grey tube and the head is leaking slightly but only while the compressor is running and briefly just after it shuts off (about 1 sec). There is also a high pitch whistling noise coming from the compressor while its running, would that be caused by the leaky gasket? Am I risking life and limb by running it with that sucker leaking?
By the way, what is that little brass fitting on the tube in the last two pictures? A secondary safety valve maybe?
