TractorJeff
Got one of those, can you fix my air compressor calls yesterday. Said sure I'd come over, turns out the pressure switch crapped, he had bought a new one based on what he thought was his operating pressure and what the salesman told him it couldn't be that must be this instead.
Background is this is a nice shop for storing the guys' Semi-Tractor when he is home. A year ago he got a nice old SPEEDAIR 2 stage compressor setup, Slow and Quiet! Then plumbed in PVC!
Argued with me that its "A-OK"! Finally gave up on trying to explain as he is a good customer.
Yesterday I got the switch installed but it now shut off at 175 not 150 like his old one. He said that is too much for the PVC air lines. I said I told you before all air pressure wasn't safe for PVC. He of course swore I didn't and listened this time.
I went back today to adjust the pressure down as I needed a Security Torx bit to turn the screw which I didn't have in my collection of tools the night before. I handed him some printed information that I got from here on PVC. He read it over and said, "well what do I do, Black Iron? I said yes or copper which ever is cheaper. I told him I would get a 1" high pressure flex hose to connect the compressor to the new pipe as the PVC is hard piped.
Just wanted to let you know sometimes you do make a difference!
On my way home I got a call from another guy wanting to know if I would be able to weld a hinge on the back of his dump truck as he got it all cut out and freed up. I looked at this right away two weeks ago when he texted like he needed it right away. I told him to cut it out and get the materials, I would put it back together as this would be cheaper for him than me sourcing and fitting it.
Argued with me that its "A-OK"! Finally gave up on trying to explain as he is a good customer.Yesterday I got the switch installed but it now shut off at 175 not 150 like his old one. He said that is too much for the PVC air lines. I said I told you before all air pressure wasn't safe for PVC. He of course swore I didn't and listened this time.
