Daddy454
Ok,I'm currently in the process of reading the "Compression-show off your compressors" thread-only to page 47 so far. I get the message as far as copper piping/black iron for cooling,but I see no mention of galvanized piping.I have mine plumbed somewhat,and in the process of re-doing/upgrading my set-up now that I've been on this board a little time.
1-what is the issue with NOT using galvanized pipe?Not necessarily for the whole system,but just random elbows/fittings here and there.
2-I see a lot of setups with big breaker panel style disconnects at the comp.I have mine hard wired from a sub-panel to a junction box to the comp.Should I put a plug/receptacle combo at the junction box,or am I ok as is?
3-I just have a small Craftsman dryer/filter right off the tank,and a reg.I've seen them set up both ways,but does it matter reg.,then filter,or filter first then reg?
Bear in mind this is not the actual setup,just mocked up to pressure test the drain valve I recently installed.I'm sure I'll get beat up a little for something,but any suggestions/comments are appreciated.
