OntarioMark
- Joined
- Jul 26, 2012
- Messages
- 10
Hi,
I am working on setting up a small air compressor in my garage. I have read a fair number of threads on the subject. I wish to cool air coming off of my compressor before it gets distributed. I know that one option is to put some zig zag lines on the wall. I have seen some good posts with photos of that design. I have also seen some suggest that a kind of "knock out drum" can be an alternative to the zig zag. The suggestion as I understand it is to take a 2" or 3" pipe about 48" long, place it vertically on the wall, on the side near the bottom of the pipe have a 1/2" or 3/4" inlet for a flexible line from the compressor, have at the top of the pipe a 1/2" or 3/4 outlet, and from there run to your separator, regulator and the rest of your system. The effect of the big pipe is to allow the air to cool and moisture to drop out. From what I have read, that one big pipe can be as effective as the zig zag and take up far less wall space.
My questions then:
1. Have I got the description of how to lay out the "knockout drum" right? Am I missing anything?
2. Is this set up as effective as the zig zag?
3. If you have the "knock out drum" system on your wall, could you please post a photo? I found only two in my search of various threads. I am a simple guy. The more I see, the better I understand. Usually.
One other question about set up of the air system. This is in regard to a loop of piping versus a dead end system. From what I have read, it seems some say that if the air system is only going to be used by a single user, then there is no advantage to having a loop system. In other words, without having more than one user at a time, there is no advantage to having the air able to come to a drop from both directions.
My question: Is this correct?
Thanks for your input.
My questions then:
