Compressor shed and reel setup
rodnok1
NC
Here are some pics from comp shed I built over the summer.
I poured the concrete, moved the compressor onto it, then built the shed around it. I used metal siding left over from the pole barn. The roof isn't as sloped as I would have liked, but price was right. I used a damaged screen door from lowes(wanted a louvered door). It let too much rain in, so I put plastic at the top of the door. I need to replace the door or build one with louvers and put a gutter on the damn thing.
Inside I put some hangers for chains, tow cables, etc. Built a shelf for exta jack stands and another at the bottom to hold all my trailer hitches ball mounts and extra ****. These pics were taken after a hella of a rain storm and too much moisture is in there.
I mounted a cut off switch in the shed, inside the pole barn I made a mount for the reg/filter and put a shutoff valve. I ran a 50ft cheapo HF(goodyear) 1/2" rubber hose over to a reelcraft reel I picked up a yard sale for 25 bucks(they had 3 I only had 30 bucks cash...damnit) It has the smaller 7/16(or 3/8) hose on the reel right now, so it doesn't give the CFM I need. It will get changed this year. I spend about 200 dollars for everything including the wire and hose.
It's great not having to listen to the damn thing running and taking up floor space inside. Now to build a shelf for air tools and the like.
