So, I've been lurking for quite a while, and I've seen this discussed multiple times, but nobody has provided a clear answer.
I own an Ingersoll-Rand 2135 TiMAX. At one place I use it, it ran off an old tank of a compressor that had a 5hp/20A motor, a huge Ajax 2-stage pump, and a 60-gallon tank through T-type disconnects and 50 feet of hose. At the other place--my home shop--it's running off an Ingersoll-Rand Garage Mate, which is a 2hp 20-gallon model feeding 25 feet of hose and Milton V-type disconnects. Line pressure is 120 psi at both places. With the bigger compressor, it has much more power under ALL conditions. The smaller compressor cannot match it even with a full tank of air in it.
It makes sense to me that with the smaller compressor, I would not be able to run the impact for as long of a time because it will drain the smaller tank much faster and the weaker pump will take a while to fill it up. But why is it that I can't even get good power for the second or two at a time that it would take to get a bolt out?
