I've got a problem when I start my air compressor for the first time each day. subsequent starts are not a problem and I'm wondering if the "warm" pump/motor are a bit easier to start?
All check valves, safety valves and unloaders are new and working properly.
When starting it seems to "hunt". Waa...Waa...Waa...Waa... until the CB pops (5-10 seconds). I do notice some sparks inside the motor housing while it is hunting. If I unload the pump for a split second (pump outlet safety valve prior to tank check valve) it takes right off. Waaaaaaaaaaaaa. And when warm it takes right off.
Not sure where to start.....
Motor not adjusted properly?
Motor starter not working properly? It is an ebay "special" Noark brand and I can't find a user manual anywhere. Trying to contact the seller now.
Any ideas Guys?
See this thread for some background info on my conversion of air compressor from 3ph to 1ph.
http://www.garagejournal.com/forum/showthread.php?t=265571
Any ideas Guys?
