COMPRESSOR SWITCH L1 and L2
Clik
Highest Mountain in Western, MD
I have a 5HP 240 Volt Air Compressor I'm hooking up.
The switch's connections are labeled L1 and L2.
The compressor instructions read Black to Black and White to White.
The wires in the wall outlet are one ground and two black wires but one of the black wires is marked with red paint.
If hots can be switched why would the electrician have marked one of the hots red?
Why would the directions read: Black to Black and White to White if they can be switched and it doesn't matter, as some say?
Do I need to determine which is L1 and L2? How? :shocking:
American Locomotive
Rhode Island
It is so you can identify which wire is which back at the breaker panel. Generally the wire should be red and black for 240v hot legs. In 4 wire 240v circuits, the white is neutral and cannot be interchanged with a hot leg.
But, many people just run standard 3 wire nm-b (2 hots, ground) which have white and black wires for 240v 3 wire circuits, and most cables only have white and black.
yatg
Southern Oregon
Because those are poor directions. As long as you have 240v between your wires, whatever color they are, it doesn't matter which one you connect to L1 or L2 on your 240v motor.
Bert_
NW Iowa
It doesn't matter. I hate electrician's who phase tape on single phase. What a waste of time
AntonLargiader
Charlottesville, VA
That's a pretty petty reason to hate someone, for spending a few seconds to clarify which wire is which. I know you're not really serious there, but still. That electrician thought it might be handy to know in the future; what's the huge harm in that?
Bert_
NW Iowa
Your right that I don't really hate them. But phase taping on single phase is never useful. It's a waste of time. There is no phase rotation and they are both the same voltage.
sberry
Brethren, Michigan
It's due to the use of cord. I tape whites in panels when cable is used 240. Just a reminder and to avoid confusion for future diy types.
pattenp
Virginia - USA
For one thing the NEC requires the remarking of a white in a cable at the terminations when used as an ungrounded conductor. NEC 200.7(C)(1)
