Compressor switch question
Iron-Iceberg
A-town
My compressor switch is leaking. I need a new switch but it looks like the switch has been discontinued. It's a Hubble 69mc8
Does anyone have a recommendation for a new one?
220V 5HP motor.
pajibson
metro detroit
Double check the check valve on the tank inlet first. They are a more common issue than the unloader
Sent from my SM-N920P using Tapatalk
N_Jay
Best price I just found for a double poll 3 to 5 hp switch is condor from Zoro.
It is easy to set up and you can get it with an unloader and manual auto-off switch.
You can usually get 15% off promo code.
I
Iron-Iceberg
A-town
Thank for the responses. Yea it's not the check valve it's leaking inside the switch. The one I have doesn't have an unloader or an on-off switch on it. I'll look on Zorro
N_Jay
If you don't have the unloader you don't need it, but the on-of switch is a nice upgrade.
N_Jay
That switch does not list the pressure range.
If you have a 2-stage pump it might be able to be set where you want it (unless you want it at 125PSI)
That said, it looks like a great price.
Alchymist
Central PA
Don't know what the max is, 1/2 turn on one adjustment screw on mine took it to 135 PSI cutout, which is where I left it.
If a higher pressure is needed, here's a similar one, no unloader:
https://www.amazon.com/dp/B00QHWBSWE/?tag=atomicindus08-20
Haven't seen/used it, but looks to be by the same manufacturer.
N_Jay
Darn, wish I saw those when I was shopping last week.
That is a great price
