compressor switch replacement
flatratedog
Howdy y’all! Getting my but kicked looking for parts to replace my bad compressor pressure switch assembly. I found the pressure switch I want but there’s no hard line coming out of the bottom of it. I tried to reuse the line from my original one and it’s not coming out at all. Does anyone know where I could buy a pipe with a built in nut on one end and threader at the pressure switch end?
The Cobbler
that may be an oddball thread on there . you'll need to determine what thread it is on the tank end .try to heat up the outside of the old switch & I bet that will help it come apart
it went in there, it has to come out,
md21722
Mt Juliet, TN
Those are normally 1/4 NPT thread...it wouldn't be uncommon to just thread the pressure switch straight on the ****** coming out of the tank.
