Compressor tank drains
lkg907
I'm just now fixiing to install my compressor and 2 tanks in the crawlspace. I've got a switched 220 outlet in the crawlspace that is switched from the shop.
The tanks will be about 4ft below the shop. I've got both of the tank drains teed together.
I figure on running the drain out in the shop and using a ball valve on the dump. Some folks tell me that I won't be able to force the water uphill for 4 ft with 125 psi. I really don't see a problem.
Your comments?
Thanks
hetkind
Johnson City, Tennessee
let run the math...33' of water equals one atmospehere = 14.7 psi
so 33'/14.7 will equal 4'/x psi or 33x = 14.7x4 or x = 14.7x4/33 = 1.78 psi
so you can push the water 4' with under 2 psi
not a problem...
or at 125 psi you can go 1.78*125/2 = 111.1 feet
is that clear enough?
Howard
metal1313
clinton NJ
yea with out math i could tell you that you've def got enought pressure for 4ft of rise. it should shoot the water pretty easy
Torque1st
MEMBER EMERITUS
KC Metro, Kansas
Just use a 1/4" dia soft copper tube or nylon plastic for the drain line to a valve up top. That avoids any large amount of water remaining in the drain line when you blast it out. Run the line beyond the valve outside.
kbs2244
One valve per tank before the tee?
Either way you cna blow a lot of water a ong way with 120 PSI.
Just run the air untill is comes out dry.
