Compressor walking away
Joevano
Zimmerman MN
I've got a big stand up compressor with 240V motor running it. Recently it started vibrating and walking away (not bolted to the floor). Also the motor pulley was too hot to touch. I thought it might have just been the extreme cold, although with the heated shop, probably not below freezing in the room it is in. Today I pulled the belt to run the motor by itself, and got this nice squealing noise coming from the opposite end as the pulley. Time to have the motor rebuilt?
OccupantRJ
Eastern North Carolina
The belt got hot because it was running loose and slipping. Disregarding the motor bearing issue, I have seen some compressors shudder violently with loose belts.
J
Joevano
Zimmerman MN
I’m told they should not be bolted down. The vibrations weaken the welds and the feet break off the tank. All is good now with new bearings.
Leaflessshadetree
Don't ask.
Loose belts and vibration can destroy bearings. Also bad bearings can cause vibration and loose belts.
Sounds like the OP took care of everything.
