calstar
I recently bought a used Sears 60gal compressor, had a leaking head gasket so I replaced it. I ran it to test and it was up to 80psi when i shut it down, no air leaks. A day later I ran it and the tank pressure gauge stayed at 0, since the gauge was oem and pretty beat I bought and installed a Winter liquid filled gauge. The results were about the same, after 5 minutes the new gauge showed 5psi. There is air getting into the tank, when I open the tank valve air escapes but the volume/pressure is nothing like it was when I initially ran it to 80psi. I took out the check valve, I could blow through it but I could not **** air through so I'm assuming that's OK. So I'm puzzled. One thing I did notice when the compressor is running there seems to be a bit of air blowing out at the intake when I remove the filter(new), don't know if this is typical or not. Ideas? The pics below show the compressor and how I installed the new head gasket, it seemed like there is only one way to install it but......
thanks, Brian
This is the way I positioned the plate and gasket
leaking gasket I replaced
thanks, Brian
