Conc sealer removal
gizmo1
How do I remove sealer from my new shop floor? I have tried regular paint stripper , bought real exspensive stripper for this type of sealer. What I have is a sticky mess. Conc is only about 90 days old.
Baada
Eastern Missouri
You may have to grind it off with a diamond grinder. It's not fun work but it's not complicated either. Just make sure you wear a respirator and have good venilation. Depending on your square footage it may be more cost effective to hire it out than to rent the equipment.
G
gizmo1
Acid won't touch it. Have about 1100 sf to do. Spent the day using gel stripper, straight hoe, & 4" razor blade scraper. Got about 25% almost done. Looks like this is going to be the toughest part of the build.
B&H
Central NY
I had to have mine ground off with a diamond grinder, then epoxy coated. Sealers are stupid unless you aren't using your garage as a garage..
Provincial
Near Salem, OR
Search is site for "shot blasting." Several threads have references to renting/hiring shot blasters to remove old paint from garage floors.
