matt151617
We just moved in to a house, and we've had a few weird electrical issues. First was a computer; it worked fine at the old house, but once we tried to turn it on at the new house, it's dead. It refuses to power on and the motherboard isn't getting power from the power supply. Second, one of our cell phones won't charge. It displays as charging but drains the battery. It never did that before, and charges fine in a car or someplace else with the same charger. Third, the can lights seems to flicker a lot, but the dimmer switches are pretty old. Last, the fridge suddenly won't get cold. It's been running continuously and never gets below 50 degrees. The fridge is 20 years old, but I find it suspicious it suddenly died once we moved in and started using more electricity. The house has been unoccupied since March. I also will note we have a minifridge and chest freezer in the garage, both of which are functioning and holding their temperature just fine.
I've checked the voltage at various outlets and get a steady 118-122 range. I pulled the panel cover (has an install date sticker of 1961), everything looks fine visually. I'm can't check the lug tightness of the service entrance obviously with a meter in place.
I'm concerned about a possible loose neutral or something else bad going on here; where should I start? Call the power company to check everything on their end? Or go straight to an electrician?
