Proud Highway
- Joined
- Jun 3, 2010
- Messages
- 19
I have a 24x24 garage in the basement of my home. Directly above it sits a 24x24 garage on the ground level which is on a suspended concrete slab.
Did the basement garage slab have rebar in it and how much?
A floating slab undoweled is best since is free to move without creating stresses.
This is good to know, my only concern is 1" of dense foam + 4" concrete = 5" of lost ceiling height.You don't have to have a thick, compacted gravel base over the footing. You can use 1" of dense foam, in conjunction with a well compacted base under the balance of the slab and REBAR, #4 at 18in each way.
Yep, you can do that.
I take it you must not have any frost depth requirements since you have such a shallow footing??
