Dutch106
Hey guys
I’ve got a 2 post 10k lbs capacity lift that I’m going to be installing in my shop. Originally I had two 3ftx3ft squares poured deeper In my pad for this purpose, but unfortunately I cannot place the lift there as it will not give me the work room needed. I will be cutting two 4ftx4ft (manufacturer’s recommendation) squares where the lift posts will be going, and they will be 12in deep. I’ve got the general idea of it down but I’m still unsure of the details.
My current slab is 4in thick at 4000psi. Where the lift will be going I will use concrete that is 12in thick at a higher psi rating. Should I also use fiber reinforced concrete?
I have been advised to drill into the sides of the existing concrete and place rebar in the configuration shown in the attached picture. I am worried that drilling into the 4in concrete sideways may compromise the strength of it and may crack it.
Would it be a good idea to dig out under the existing concrete prior to pouring the new sections? I think this is known as underpinning.
Where I will be pouring these sections is near a pre-existing control joint. In the attached pictures you will see where the final lift post positions will be. Should I bring the edge of the new sections to the control joint or overlap the control joint with the new sections thus eliminating a portion of the control joint?
The lift comes with 5.5in Long by 3/4in wedge anchors. The holes in the baseplate of the lift columns measure closer to 1in. I’m think of using 1in diameter wedge anchors instead.
Thanks
Thanks
