Iceman22
Before I go any further I want to thank all of you for your knowledge and willingness to share it. The vibe here is completely different than some of the car forums I am a member of where you will be quickly crucified for asking what is perceived as a dumb questions/question that have been answered. The being said you all have already been a huge help in my in my previous 2 threads which has now lead me to my current position...
Initially I was I was moving forward with the plan of having a pole barn attached to my current stick built house. However, after taking into consideration all of your thoughtful responses, I have begun the process in getting quotes for a stick built garage instead. I had hoped the pole barn construction would allow me to keep building costs lower but it just appears not to be worth the "side effects"
That being said the multiple contractors I have spoke to so far all state they do not do concrete and therefore would only be interested in the work once the concrete is poured. Not only is that okay with me but I think I prefer to have someone pour the concrete where that's all they do...
Therefore I contacted multiple concrete guys who all said the same: we'll do whatever you ask for but keep in mind you'll want to be sure whatever you have us do is compliant with the city. Initially I was put off by this, thinking "shouldn't you know what they want?" However, after speaking to multiple concrete contractors in the area I'm beginning to think this is the normal response/thought process.
With that being said I went ahead and contacted the gentleman who overseas the cities building code and inspections. While not rude, he was of little to no help. I asked him multiple questions such as if there was any city regulation regarding the maximum size a slab could be poured and if I could get away with a no-form haunch. His response to every question was the same; "The city follows the 2015 international building code guidelines for all construction. Your best bet is to submit what you plan to do. We will then compare it to the 2015 I.B.C and either grant a permit or return it to you with what needs to be adjusted."
So, my question to you guys is; are any of you aware of what the 2015 I.B.C. says with regards to a concrete pour on an attached but
unheated/un-insulated
28'x40' garage? The site of the proposed garage is more or less level....
