thomas_oehlke
I do not know exactly what topic this gals under on this website so I apologize if it is in the wrong spot, but I currently poured (poured on 1/30/2020) a concrete bar top in a mold and it’s my first one I’ve ever done so the troweling looks a little rusty but that’s past the point. I came onto this forum because I made the rookie mistake of sanding the concrete with too coarse of sandpaper, if I’m even suppose to sand concrete, while it was still green/wet. I now have slight scratches all over the top from the orbital sander I used. I was using 120 grit thinking it would be fine enough not to scratch it but once I sanded the entire thing and blew the dust off with an air compressor, all the scratches appeared. I’ve tried using a little finer sandpaper and eventually very fine sandpaper but no difference was achieved. I am planning on acid staining it brown and sealing it with many coats but I want to know if there’s something I can do to get rid of those scratches before I stain and seal it, unless staining and sealing it eventually will get rid of them. I’ve included pics of the bar as of now after I wiped it off with water and paper towels. If anyone knows any good advice to remove those scratches, it’d be greatly appreciated because I’m ready for my next step as soon as someone reaches out to me. Thanks.
