rmmiller
The building where I work is a concrete tilt up and we have some issues with it. What we have are cracks, some substantial and others just cosmetic. We need to find someone to repair it but I also thought I would fish for info on how to properly repair this. I figure it's better to be somewhat educated on it before talking to a contractor. So here are some of the bad areas.
This door is in the back of the building, it has reached a point where you need to pull the top away from the wall to open it.
This is what it looks like on both sides of the door.
All along the back the joints where the all sections of wall come together looks like this. None of this shows up on the inside of the wall, just outside.
This side of the building sees the brunt of the incoming weather which I'm sure has helped the deterioration along. Compounding the problem is the lack of maintenance over the past couple of decades. We are now under new ownership so I am hopeful we can get this addressed.
So...any good suggestions or info on proper repair?
