concrete crazing? help
malodin
Hi well after pressure washing my floor after it had not been thoroughly cleaned after a muratic acid bath(MY BAD) so while pressure washing it i noticed little lines(not cracks but lines) i can get pictures in a few hours. I want to put some acrylic concrete sealer down this weekend but not if i have to do another step...please help
M
malodin
WolverineCoatings
Spartanburg, SC
Can I suggest using our AcryliSeal 3501. While you can use any acrylic, the smaller the molecule of acrylic the more penetration you will get. The deeper the penetration the more strength you will put into that top layer. (Our AcryliSeal 3501 is the first nano-polymer Acrylic to be commercialized.)
While AcryliSeal is a little more expensive than your average acrylic... the performance is exponentially greater.
See Fred at AlphaGarage...
M
malodin
i will email him on that. but what is the lines in the concrete?
thegarageguy
Don't worry, it's just that the top of your concrete slab dried out a bit too fast and you got a mesh of tiny hairline cracks. These do not hurt the structure or strength of the slab.
Acid staining may look incredible on that slab.
WolverineCoatings
Spartanburg, SC
Ohhh... I bet it would...
There are acids mixed with different metals that stain concrete. The only problem is that you've already acid washed. IF... IF... IF you've removed the 'cream' layer then the acid stain won't react and won't color. You may not have removed enough for that to happen. But, it's cheap enough that it would be a low dollar risk to try. Once you acid stain... then you neutralize... rinse... Apply AcryliSeal 3501 on top to protect it.
Good thinking garageguy...
M
malodin
due to time restraints i am going to just acrylic seal it today. thanks for all your guys's help
04 Navi
PNW
Hey not to hi jack this thread, but would you need to seal the acid wash with metals in it to maintain the color or not? I am talking about my outside cement patio btw. Thanks.
WolverineCoatings
Spartanburg, SC
Yes... You may notice as you go into restaurants that have acid stained floors that there is a black path where people walk. Once the sealer wears away it just starts looking nasty as dirt settles in the concrete pores.
M
malodin
So after pressure washing it again and sweeping it all out those lines in the picture dissapeared and i let it dry out over night and then sealed it(then i had to leave so i wont know what it looks like till i come home saturday)
