kngelv
I recently had a new garage built and also some concrete poured to extend the driveway to the garage. The concrete work was done beautifully with a nice pitch for drainage except for one small area. On a section in front of the main garage door there is a low spot of about 12 inches by 18 inches where water pools to around 1/8th of an inch in the center and a 1/16th on the edges. I had the contractor out yesterday and he gave me two options. #1 Cut a gradually deepening line from the center of the low spot to the nearest expansion joint (around eight inches away) so the water will flow out. #2 is to use a product called Mapei Planitop X http://www.brockwhite.com/0p46i615/mapei-planitop-x/ which is a polymer mortar/concrete repair product. He claims they can feather this in to raise the concrete profile. He says there will be a slight color difference that will gradually fade. Any thoughts? Thanks.
James
James
