jav
I'm in the planning process for building a new garage and thought I had decided on a power troweled concrete slab finish (almost polished). But- I also wanted to seal the wet slab to minimize staining and to aid in the curing process by eliminating premature drying.
I was trying to research if chemically sealing a wet slab pour and, then power troweling, were compatible. I couldn't find much but what I did find is that power troweling can close off the top pours of the slab and prevent proper evaporation and is generally regarded as a bad thing?
Now I'm confused- I thought it was best to allow concrete to cure via the chemical reaction-(in some cases even completely submerged under water) for producing the strongest concrete with the least surface issues? I understand some of these power troweling reports are geared towards slabs passing entrained humidity and initial cure strength tests in commercial buildings but what are the implications for a garage slab?
Is it advisable or not to chemically seal or densify a freshly poured slab? Is it advisable or not to chemically seal it IF power troweling is planned? My goal is to end up with a slab that is almost polished, non dusting, hard to stain and easy to wipe clean.
