Those look like control joints, not expansion joints. We do not fill control joints.
Thank you guys for the terminology. That is so important to communicate properly. That term make sense, it "controls" the cracks.
Yes, they are control joints. Does that mean I should not fill them?
The expansion joints look fine. Which makes sense about your comment of finishing the control joints, instead of cutting them.
I did not measure, I just step it off. Here is a picture while I describe the size. I guessing about 3ft per step.
From road to single garage door 96 feet.
Width about 15 feet.
Width in front of double garage door about 18 feet.
Distance from double garage door to curved part about 18 feet.
The drive going back to the shop is about year old and seem to be ok, but does not have the traffic the front has.
If I am guessing right there is about 180 feet of control cuts in the main drive.
I wonder why this drive is susceptible to tire marks. I just had a storm shelter installed in the double door garage. This picture was taken after backing trailers and the bobcat had rubber treads. So it looks worse than normal, but there is always marks. They wear off fast. I always assume it has to do with the approach to the double door garage. You have to make the swing just right depending on which side you are lining up for. My wife and I have it down now. I always suggest that people test before laying any drive down. The main drive was in we bought the house. The sub contractor that did the drive to the shop worked with me to get it right for the door in front of the red Grand Prix. There was a plan in case I put a fence across the front.
Just to be clear, the damage pictures was before the shelter installation.
