klean63
I have a post in my garage, it's 3" diameter x 3/16 wall x 26" tall and filled with concrete, it's off to the side of the garage but it's in the way of some storage i'm planning. I'm not really sure of the best way to remove it.
1st thought was to put a metal cutting wheel on my makita, cut around the diameter of it then change to a concrete cutting wheel to cut thru the concrete. The problem with that method is the post is about 2" away from a wall so I wouldn't be able to get around it all the way.
2nd option was to use a reciprocating saw but it can't get close enough to the ground.
I guess my question would be, will the metal cutting wheel cut thru the concrete? I know it's likely going to eat up a a few cutting wheels but if it'll get thru i'd have no problem buying a few to get it done.
You may find its code to be there as well.
