Concrete GenPad vs. KwikPad
AffableCurmudgeon
Triad Area NC
Hi, I am looking to get a 22 kw Generac natural gas whole house generator and ATS installed using a local electrician. It will sit on an uncemented area.
Are there any major differences/benefits over using a concrete GenPad or a composite KwikPad under the generator? Is one better/worse than the other? Not concerned about the price difference between the two. I am in NC.
Thanks.
mm08822
Regardless of the pad type, I always place them on top of 4" gravel.
I used to pour my own 3' x 5' pads but with all of the price increases, a ready-made pad is less labor (I was hand mixing).
My only experience with a concrete gen pad was that it was received cracked and had to be replaced by supplier. It sucked moving all of that weight at once and getting it level - pry bars, etc. Hard to keep tamped level gravel in place when moving the base into position.
The first hurricance pad (plastic) I worked with was warped. "Leveling" that was a challenge. Once I bolted the gen to it and filled with water, I had to re-level it.
Since the first one, the others have been installed w/o issue.
In NC, you may not need gravel underneath. Have the pad set higher than grass to help protect gen from mowers.
