kaffine
I need to grind a couple of slabs some before putting down VCT. I have 2 small rooms around 12x14 and my shop 28x28 to do. I can tear down the wall between the 2 rooms making it 12x28 if needed. The shop slab is in fairly good condition just a few high and low spots. The other slab is in bad shape and the concrete is weak, also there is also an adheasive residue I've used a scraper to get up all I could get with a pole scraper what is left isn't sticky.
Can 1 type of grinder handle both slabs or do I need to rent 2 diffrent machines?
My local rental yard rents Edco 7 inch 10 inch turbo grinders and a 22 inch dual disc grinder. Which would be easier for someone that has never used on before? I also have some concrete to practice on if needed that doesn't matter if I destroy it.
Do I need to rent a vacuum with it or does grinding it wet keep the dust down enough that the vacuum isn't needed?
Thank you.
Thank you.
