So it looks pretty bad in my garage at the moment. Every time I raise a car on the jack or use jack stands my floor peels up..... The problem stems from sealer on the concrete. However, what ***** is that I talked to Epoxy Coat about the proper preparation needed to get the coating to stick even though it was sealed. The steps I went through were the following:
1) Stripper/Degreaser to get rid of the sealer
2) Rented a diamond grinder from Home Depot...I believe it was the Dimabrush and went over the surface three times.
3) Multiple sessions of pressure washing to get all the gunk out.
Not knowing how aggressive the diamond grinder should have been I think was the issue. I got some dust from it....some scratches on the surface, but I don't think it dug in as much as was needed. The concrete was still really black. So, after all this prep Epoxy Coat agreed that it would be good to proceed. Only a couple weeks later it started peeling up. I went through a month of tests from Epoxy Coat for them to say that the sealer was still on the concrete and they couldn't do anything about it.
So, I guess I'm SOL and need to grind everything up. What piece of equipment is needed to take a big aggressive cut on the concrete to remove the sealer and get a surface that the new epoxy can adhere to? It seems that the concrete is really hard....
Thanks for your help/suggestions
