Concrete leveling for lift
Exiged
Hi guys!
I have an older garage that had a recent floor poured in that is not level and even has some good 1" dips here and there. It was a quick job that I should have paid to do right but that didn't happen. It's not really a huge deal as it works fine for my needs but now I want to put in a scissor lift. My problem is the floor isn't level enough or even enough for a scissor lift. So is there away to get a section level just for the lift? 6x6'? Besides taking it all out and redoing it or cutting out the floor and dropping in a fresh poured section for it.
Yes I realize I should have done it right the first time so please don't drill that into me further :)
Vegaman_Dan
Pacific, WA
Any leveling compound you put in there will chip out the moment you put the concentrated weight of a scissor lift on it.
Unless you want to replace the concrete the right way, any patch will be just that.
I would recommend getting a sheet of 1/4" steel about a foot larger in each dimension than your lift. That will give you a very smooth and strong support base. It wouldn't be a bad idea to use that leveling compound on the concrete before putting the plate down since the plate will distribute the weight nicely.
A steel yard can cut a sheet for you. It might cost a couple of hundred dollars, but it's the easy and simple solution.
E
Exiged
Good idea! I'll prob get some steel and grind out the concrete till it's level on each spot and put the steel down
