Concrete/masonry screws for conduit.
acer66
Western North Carolina
Hey,
Ran some conduit on brick and the screws at hand were blue and while they work I almost want to paint them.
Which got me wondering what brand/type of silver screws for attaching conduit etc to concrete/masonry the pros here are using.
Thank you.
onetonbb74
Gilroy
I use blue screws, don't need to oversize the hole to fit a plastic sleeve with the other concrete anchors. I also use 1/4" wedge anchors and use washers and a nut if I need the extra strength.
MovingAlong
Hey,
Thank you.
I paint screws to match all the time, even blue ones. Why wouldn't you?
A
acer66
Yeah, that is why I normally use the blue ones too.
This was for a friend in an old brick live in basement with everything surfaces mounted and it looked all good until I started to see the blue heads everywhere. 😱
Friend did not care but if I would do something like that for myself I would not want blue screw heads.
Crazyjake8493
Upstate NY
We use a lot of Hilti screws at work. Silver, and grab better than tapcons. They do require Hilti's bits with the correct tolerance. They're also expensive.
I use either tapcons or plastic anchors and stainless #10x1" screws quite often outside of work.
dscheidt
you can even use a pc of copper wire in the hole and use regular plated #10 wood screws .
i end up needing to do that with tapcons in brick half the time. the brick around here is soft, and doesn't hold threads.
