Build your form to suit the shape with screws so you can remove them in time to finish the edges. A 1 x 6 out side of a 2 x 4 should do it. You won't remove the 2 x 4, just the 1 x 6 to tool the bullnose. Vibrate that area well to not have voids. Keep some wet mud handy to patch and float as you come upon a void.
Overhangs are a matter of timing. I'd build a short mock up and fill it with a sack of ready mix. Actual ready mix won't be rich enough to work well, so if you're successful, you'll be ready at showtime. By adding some more cement it will get better at holding a shape once the form is removed. A WAG would say remove the outside form in about an hour. I'd build the form in short sections for control.
2" is a little thin so your aggregate has to be sized accordingly.
