Concrete or masonry nails for these cinderblocks
ive
Canada
Hi all.
Mom doing a piece for my mother in law. I put some tapcon screws in the cinder blocks but they are not holding well. I can tell the tapcon isn’t tight.
Would concrete or masonry nails work? If so, which one? Any other ideas appreciated.
Thank you.
Bert_
NW Iowa
Remove tapcon, insert a piece of copper wire, reinstall tapcon.
I use the method with plain wood screws in concrete sometimes. Holds very well.
I
ive
Canada
I think cinder block. The block seems kinda porous. Would that be right?
I’ll post a better pic tomorrow
Vtor
Left Side of the Moon
I've done 12 or 14ga copper wire or tooth picks / bamboo skewers in the past when a hole gets wallowed out or block is very "light".
Or you use wrong bit.. 5/16 looks awful lot like a 1/4" !
dogdog
I have to resort to those Hilti finger mesh on 2 part anchoring epoxy mesh screens... works nice, let it set for 24 hours and don't disturb it. Was pretty expensive. but I am setting 1/2" bolts to the wall for shelves.
HILTI Epoxy Anchor Screen, steel mesh
paredown
Pomona, NY
Did you use the proper bit to drill the hole or was it bent ? That will make a difference with Tapcons.
And a fresh drill helps too.
Thanks for the tip about copper wire--filing that away for the next reno section where I'll be back dealing with block....
quickfarms
Southern California
West marine epoxy is my go to solution for loose fasteners just make shore you coat the fasteners with WD40 before inserting them into the hole or they are permanently in the hole
At work we drill the hole and use soft lead to take up the slop because it is faster than epoxy
I
ive
Canada
Hi guys. Thanks for the ideas. Would they work on this type of cinderblock?
