jalmbe5
When I built my shop I intended to have 2 roll-up doors, so I formed recesses at the door locations. I actually made them sloped instead of just flat like commonly done. I ended up only installing one door, but framed and blacked in for the other. I've decided to do away with the 2nd door and re-frame that section to just be straight wall. See my attached drawing for a better idea of the situation. The only concrete product I have experience with is your standard sack concrete mix. I need a concrete or epoxy product that I can use to fill the sloped section before I re-frame the wall. If possible, I would like something that can be feathered to nothing. If absolutely necessary, I can cut/chisel away enough material to create a 1/4" to 1/2" deep lip, but I would rather not have to. Something as easy as mix, pour and maybe level off if necessary would be ideal. Is there a product that would achieve this without a great deal of effort?
Thanks
Thanks
