Concrete prep for sealer ...
1953mercury
Steamboat Springs CO
I have 2100sf of 1 yr old floor that I want to use a penetrating sealer on. Also have a floor burnisher/buffer and would like to know what type of pad or cutter any of you may have used successfully for this purpose. Thanks, Mike
LegacyIndustrial
deerfield, IL
If it is free of any sealer, a good scrub with some simple green should do it.
If using a buffer (175-300 rpm) a white pad might help.
Armorpoxy
Hi,
We have an excellent sealer for this, please email us directly for tech specs and pricing. Thanks
Garage Flooring
Grand Junction, CO
Just keep in mind.... Penetrating sealers do not generally leave a film on top of the floor. So use the least aggressive method possible to strip what is there or as Scotty has explained in the past you are going to have a floor that catches every piece of dirt and grime.
