Concrete Prep
Dyno Dan
Southwest Montana
I have silty loam soil in an area that is essentially a drainage from the surrounding mountains. I brought in 854 yards of 4" road mix (yikes....that hurt the budget) that was compacted between truck loads. The dirt work was done back in August of 2017, and then my 36x60 pole barn was built in October 2017.
Since then I haven't done much to the building, but I've been chipping away at electrical (now that I have 100amp service), installing some "bash boards" on the open side, and planning how to finish inside of enclosed bays (wall material, insulation, and concrete floor).
My million dollar question is can I pour concrete on the 4" road mix after another round of compacting? My intent (budget limited) is to have concrete only on the enclosed side. I have a 2x8 baseboard / skirt board and the current gravel floor needs to be leveled to take care of high / low spots. How thick should I pour? Also, do I need to have a foam buffer around the slab to avoid bonding the concrete to my posts?
Usage > I intend on parking regular automotive stuff and toys, and perhaps a 4 post lift.
Heat > In floor heat is probably not in the budget so a propane fired radiant tube heater or convection heater will most likely be used.
Kaizen
New England
How thick is the base inside the building? What was used to compact it?
D
Dyno Dan
Southwest Montana
Sorry about the double post.
The base is something like 3-4' deep! Compacted with the equipment show in pic. I'm not too handy in knowing my commercial construction equipment :)
ConCretin
Central Maine
Looks like they used a good sized roller, which should yield good compaction. You could have the material tested for compaction if you want but I wouldn't be reluctant to place a slab on what's there.
D
Dyno Dan
Southwest Montana
So another layer of?? I have since talked to an old friend who has done well with concrete construction here in the valley. He said crushed stone would be ideal, but he would even consider 3/4 minus gravel, compacted, as a solution as well. God knows I could use a load of 3/4 minus to "smooth over" some other areas around the shop as well, that 4" road mix is pretty rough in places.
Chris705
The Finger Lakes of NY
Do you need to bring the grade up at all if you placed concrete in either a 6 or 4” thickness? Then you can bring in some nice fine graded well compacting stone. If no added fill is needed to get to your selected concrete slab thickness then I would move forward with the fill you have in place. If the top surface is lose and you think a plate compactor will firm it up, wet the surface a little bit. I’d also suggest a 6 or 10 mil. vapor barrier prior to placing your concrete....actually look at post #5...be sure to read all of LLWillysfan guide to floor slabs! Ask any further questions you may have here, we’ll offer plenty of advice.
Do you need to have a foam buffer around the outside? Well not exactly But you may want to install some thickness of insulation at th slab edge to temper the freezing cold from sucking any heat you try to add to the inside....
Kaizen
New England
As much as I hate to say this...you need an engineer or soil engineer. That is a lot of fill even if compacted right it sounds like bad soil under it. You don’t want to waste money and have it crack up
D
Dyno Dan
Southwest Montana
OK, I've got some reading to do (LLWillysfan Guide to Floor Slabs), thanks for that. I did some quick eyeballing last night and there are definitely some high spots, and low spots. The back left hand corner in particular is low and I can see day light under the 2x8 skirt board.
I'd like to end up with a true 12' ceiling height. I pulled a tape from the ceiling liner down to the 2x8 skirt board. Looks like 12' lands about 2" down on the skirt board....if that makes sense. So working for the floor up, there would 5" of concrete, and then 2.25" to the top of the skirt board. I was looking at doing bookshelf girts and insulating the wall, so I suppose I can put the bottom bookshelf girt flush / even with the top of the skirt board.
If I want to maintain a 12' ceiling, it appears as if the concrete would need to start at the base of the 2x8 skirt board.it looks like I'll need to pour starting at the base of the 2x8 skirt board, 5" of concrete, and that leaves
Chris705
I had a tough time leveling out my fill after a couple years of driving & working on it. A rotary level helped me define the low’s and high’s so I could get it to about 1/2” difference.
Adding rigid insulation at the skirt board w/ a 45 at the top edge will quickly close the gaps under the board. Would you be adding some exterior top soil around the perimeter? I also poured a 5” thick slab.
D
Dyno Dan
Southwest Montana
Foam board on the outside?
I have a 15’ cushion on each side and 5’ off the back side. Same material, same compaction, etc. I thought I would add lean-to on each side some day. A man can dream.
Bretny
Dutchess county NY
Make sure you put concrete underlayment under the concrete. Basicly thick thick plastic. Some people forget this then have to deal with a moist slab for years.
D
Dyno Dan
Southwest Montana
That I can do. Looks like I’ll need to remove some material to get level with bottom the skirt board.....and maybe a bit more to leave a few inches for new base material.
Chris705
Insulation board on inside face of skirt board.... I suppose knowing you are planning on insulation with the bookshelf girts you don’t need to trim top of insulation board at 45 degrees. Just place top edge at top of slab height.....
D
Dyno Dan
Southwest Montana
What board / what thickness? Also how deep? Does this negate the need for expansion joint foam?
Reading LLWillysfan's write-up: "Insulation - In heated structures, particularly with in-floor radiant, a minimum of 2" of rigid board insulation is typically placed under the slab. You can use either XPS or EPS as long as it meets ASTM C578. In cold climates, rigid insulation should also be used vertically on your frost walls to keep frost from getting under your slab through the walls.
For slabs under unheated structures, you can protect the structure from frost movement by placing insulation under the slab and extending it out or down 4' around the perimeter. The insulation will retain the natural heat from the ground and keep the frost from getting under the slab.
I'm going to be heated, and I could put foam under the slab, but I don't have a frost wall in this case. If the foam is up against the skirt board on the inside, it sounds like I'll be doing some shoveling.......but how deep?
ConCretin
Central Maine
The first function of underslab insulation is to improve heating efficiency particularly with in floor radiant. This requires insulation between the slab and the ground and the air if the edges are exposed.
An equally important function is to keep frost from penetrating under the slab around the perimeter. With frost walls, insulation can be laid against the wall before backfilling to provide a frost barrier. A floating slab such as in your pole barn requires a different approach. You could dig a trench to your local frost depth and install the insulation vertically or an easier method might be to lay insulation horizontally out the same distance. This insulation can be run as deep as necessary to allow for lawns, pavement, etc
this has added benefit of protecting your structure from frost in the event your heat is turned off for whatever reason. Pole structures are a bit different from what i'm used to so others may have other ideas.
D
Dyno Dan
Southwest Montana
Hey guys I’m back. Wiring, bookshelf girts, garage door operators are all done. I did 1.5” foam board between the girts and plan on 2-3” of foam over that.
Next up is concrete. I have to move some stuff out of the way and then start removing some compacted 4” road mix......ick. That is if I want a full 12’ inside ceiling height
Any who, as you can see in the pic I didn’t run the bottom BS girt yet. I had a thought, and now a question. If I ran the last BS girt and then a 2x8 skirt board on the inside of the structure (forming an “H” shape), would that yield any benefit? Would the slab be in a better position to float, and could I then insulate the inside face of the existing skirt board? Does that help, or is it just an asinine idea?
lakeroadster
Central Colorado
I wouldn't do the H shape. You've created a pathway for burrowing animals and varmints to get into the building.
Leave the bottom bookshelf girt off. Pour the concrete. Then install the bookshelf girt a couple inches above the concrete so the slab can move relative to the building.
D
Dyno Dan
Southwest Montana
Ok, I removed some of the 4” compacted road mix and got it level with the bottom of the skirt board. My little JOhn Deere 1025R got a work out.
Then I got a load of 3/4” screen rock (that’s what the gravel pit guy called it) and laid down about 1.5” of it so far. I’ll rent a plate compactor this weekend and make a few passes while pulling a string to check for level.
So at the garage doors I’ll have to make forms? Anything needing to be done on the inside?
ConCretin
Central Maine
That looks like a nice solid base. I would consider thickening the slab where you drive onto and off of the slab. I'd probably throw in a couple rebar in the the bottom for good measure. You might want to install expansion foam around the entire perimeter or just around the posts to isolate the slab from the structure. If you have a minute, you could give my Guide to Floor Slabs in the link below a read for some additional thoughts. Great work so far.
matt_i
When doing the block-outs for the garage doors, I recommend forming a small pocket for the door to sit in, slightly lower than the finished floor. Even if its just 1/8" lower it will help keep wind driven rain from going under the door and causing irritation. 1/4" is better but may require some advanced planning as the door may uncover the trim at the top if it drops an additional 1/4" lower. Its a detail that seems like "you can work that out later" but when the grey mud is flowing there isn't time.
I'm going to recommend some kind of long-distance level to get the stone base leveled. It doesn't have to be uber-precise but that can throw off your concrete delivery volume if you have a drop over a long distance. Rotary laser level on "coarse" is best/easiest but a water tube level will do the same thing at lower cost and slower.
I like to use curing sealer on concrete to get max strength without the humidity bomb of wet-curing and saw-cut any control joints the next morning after the initial pour. 10-12' squares.
D
Dyno Dan
Southwest Montana
Expansion foam will be installed around the entire interior.
I do plan on #3 rebar at 24”o.c. On the idea of a thickened edge at the doorways, you’re talking about additional rebar?
Thanks for the support and encouragement.
D
Dyno Dan
Southwest Montana
Thanks for the tips. In regards to the door channel / trough, isn’t that a recipe for a frozen door seal and gravel trap? I’ve got plenty of both (cold/wet, gravel).
I was actually contemplating putting in a floor drain before I get any further along, but this may be above my capabilities...... maybe ;)
ConCretin
Central Maine
That sounds perfect. Yes on the extra bars. I'd thicken the edge to 8" or so and install a couple bars in the bottom.
D
Dyno Dan
Southwest Montana
Perhaps a silly question, but on the foam I going to use what was suggested earlier in this thread. Question is how to retain to the skirt board and posts? Looks like what is referred to as "cap nails" is the hot ticket?
These?
Also, after the pour does everyone recommend saw cuts (the space is ~25x35)? Lastly what’s the preferred method to “cure” the slab? Keep it wet for a week or seal it the day after the pour? I do plan on an epoxy coating if that matters.
D
Dyno Dan
Southwest Montana
Put down some more material on the other side. I have no idea on how level things are, but I suppose after running a plate compactor I can pull some strings.
matt_i
Saw cut the next morning after the pour is my advice.
Curing sealer is a set-it-and-forget-it solution. But its likely that coating will eventually have to be ground-off.
Wet curing is a possibility but the internal humidity can wreak havoc on things you don't want to rust...but...along those lines, the entire building has to be emptied anyway, so that might be a moot point.
See below on the potential gains from proper curing.
https://images.app.goo.gl/LeMcihGdXmbyGvL56
spudley
Northeast Wisconsin
We poured my floor at 7AM in July. Saw cut the slab at 7PM that evening.
If you're doing epoxy, do the wet cure and skip the sealer.
As far as rust, it's pretty dry out there.
Are you in Paradise Valley? Beautiful area.
ConCretin
Central Maine
The ideal method of sawcutting control joints is an early entry or 'soffcut' saw designed to cut green concrete immediately after finishing is completed. Tension from shrinkage starts and early and the sooner you relieve it with control joints the less likely you are to have random cracks.
Moist curing is ideal. Keep the slab wet by ponding, fogging or covering. The best method in my experience is a curing fabric such as Koncure. Wet the slab, roll out the fabric and forget about it for a week or two. Spray on products are fine but as had been mentioned, can interfere with the bond of future floor coverings.
D
Dyno Dan
Southwest Montana
Sounds like wet cure will be the way to go for me.
I’m over the “hill” from Paradise Valley in the Gallatin Valley to the west.
spudley
Northeast Wisconsin
My buddy built in Paradise Valley. My son lives in Boise so I stop on the way out and spend some time in your area. Beautiful mountain views.
Looks like you have a good start on your project, but if there's anyway possible to squeeze in floor radiant into your plans/budget...do it, even if you don't hook up to a boiler or water heater now.
I'm using a 75K gas heater in a 1000 sq ft shop (oversized but free) but the feet get cold, and I don't like woodworking in boots.
Anyway, listen to everything LLWillys says and you won't be disappointed. He is the GJ concrete guru.
Good luck!:thumbup:
D
Dyno Dan
Southwest Montana
A bit more progress today.
lakeroadster
Central Colorado
That's going to be nice Dan. You are doing a fantastic job.
I'd suggest you put up some thin plastic poly sheeting, Visqueen, temporarily on the walls before they pour the concrete. That way you won't end up with concrete splashed up on your columns, girts and insulation board.
I just used a staple gun to attach it...
I wish your "gravel pit" guy would have sold you crushed rock though... it compacts so much better. Rock with smooth edges just doesn't lock into place well. I know that's no help to you at this point, but might help somebody else that's reading this.
D
Dyno Dan
Southwest Montana
Thanks for the tip John. I was thinking that I could run the vapor barrier that I’m putting on the floor a little long and run up the walls a couple feet. See any harm in that? Of course I’d trim it back once everything is settled.
lakeroadster
Central Colorado
Might be difficult to get the vapor barrier plastic to sit nice and flush around the posts. And you don't want it laying in the concrete and being a hassle for the guys finishing the concrete.
I'd do the splash barrier all on it's own.
Are you putting in any reinforcing steel / mesh?
D
Dyno Dan
Southwest Montana
Slow going. I’ve got the 3/4” screened rock as flat and level as I can get it. Added some moisture, ran a plate compactor, checked, added / removed material.....repeat.
I ended up buying Stego 15 mil vapor barrier, sealing tape, #3 rebar, ties, and chairs the other day. Next step is the vapor barrier.
D
Dyno Dan
Southwest Montana
.....and more
