Concrete question... not in my garage...
Jaguar Fan
Park City for Ski Season; Las Vegas for Poker Seas
Question for those of you who know about such things:
Attached are a few photos of concrete "bridge" over pool water in my back yard. You can see the color is splotchy & faded. What product should I use to try to make this look better? It was originally a dark grey. IMG_5508.jpeg
Rusted Nut
Northern Arizona
Try cleaning with a concrete cleaning solution. Don't use too much, and don't slop it on the other concrete, it can get blotchy doing that. See if that works first.
Pretty nice looking pool BTW.
signcrafter
If you get it wet (just regular water) does it look like what you want it to look like? If yes, it is very likely that Miracle Sealants 511 Seal and Enhance will solve the problem.
Need to answer this question and then can give advice. When it's wet with water does it look like it should? If so then it just needs to be cleaned and sealed. If it still looks like your pictures when it's wet then it needs to be cleaned, colored/antiqued, sealed.
J
Jaguar Fan
Sorry for the delay ... life got in the way.
Here are a few before/after pictures this morning. It appears that when wet, it would look pretty good. Once wet, there is a lot of reflection from the water on it. The water does not "bead" but there is a uniform sheet of water maybe 1 or 2 mm thick - so then I took a squeegee to it to remove standing water and the wet concrete still looks pretty good this way. Not perfect, but a very good improvement.
BEFORE (DRY) :
AFTER (WET) - but there is a standing sheet of water on the concrete perhaps a millimeter or two thick, so much of this photo is really reflection bouncing off the standing surface water:
WET - but AFTER I took a squeegee to it to remove standing water. The concrete is definitely wet, but there is no standing water on its surface. It isn't perfect looking, but pretty good. It looks better in person than in the photo.
duneslider
Riverton, Utah
If you are happy with the color when it is wet and squeegeed off then I think the miracle 511 seal and enhance will make it look like that. I am sure there are other products that do the same but that is the one I have experience with. The 511 is a penetrating sealer and not a topical sealer, so it won't change the surface like a topical sealer would. The 511 will need to be applied every year or two probably. A topical sealer might last a little longer but they look more like there is a sealer on the concrete.
I am guessing you just have some natural etching that has occurred on the top finish, which could be from the pool water, or just rain sitting on it. I suspect you could acid etch the concrete and get it more consistent but I would try the sealer first.
