bob_mp
Greetings,
I am building a 22x44 garage in the Bay Area, CA. I am finalizing (upgrading) the plans for the concrete work, which hopefully starts in 2 weeks.
The garage is designed with a perimeter foundation with a floating slab which has a reinforced edge. I am planning on installing a 2 post lift and getting an epoxy floor coating. Attached is a drawing showing the foundation and the slab.
I'd appreciate some feedback on the plan and have some basic questions.
Here's what I am planning:
1. The slab thickness will be 6" with #4 rebar on 12" centers.
2. The rebar will be supported by chairs.
3. 6 sack concrete (3500-4000 PSI).
4. Max slump for the slab is 3", for the foundation, 4".
5. Stegowrap 15 mil vapor barrier underneath the slab (no penetrations)
6. Control joints cut to a depth of 1.5"
7. Curing the concrete for 7 days with a sprinkler (or few)
Some questions:
1. Should I add fiber? I understand it helps control cracks early on, but is probably of limited utility afterwards, given the rebar. It's not very expensive to add. Does it create any issues for an epoxy floor, given that I will be grinding it down anyway?
2. What is the role of mid-range water reducers? Is that something that my engineer should specify to use or not use? Do they provide better workability without reducing strength?
3. What, if anything, should be done between the lower edge of the slab and the foundation? Is it just the vapor barrier? I read somewhere that it's a good idea to have a 1/4" of sand at the top of the foundation and below the vapor barrier to add as a bearing surface to avoid putting the slab in tension. Is this a good idea?
4. I am planning on using a reputable concrete company. That said, should I ask them to perform a slump test?
5. Should I avoid having a control joint between the posts of the lift?
Anything else I should be doing?
Much obliged for the help.
Bob
Some questions:
Bob
