Concrete repair
wssix99
Chicago, IL
The best thing(most durable) is to cut out a section of the floor and re-pour it. If the patch is less than 2", then concrete won hold up as a patch and you'll have to use something synthetic.
K
Kaoskido
I'm sure I can cut out that bad section.
wssix99
Chicago, IL
If that section is really heaving, you will want to find out why. The whole floor should move together if you cut and pour down to the base of the slab. So, just filling the section should be fine.
If you want additional insurance, you can epoxy pins in the sides of the cutout or chisel a notch/keyway in the cutout so the two pieces interlock.
wssix99
Chicago, IL
So given it is a small section what type of concrete do you suggest I put there? I.e. Quickcrete, etc
Yep. Just plain Jane concrete in a bag from your local home store. If you give it enough depth and don't mix it with too much water, it will hold up like any other concrete.
Also, what do you mean by keyway?
Are you saying to make the top cut narrower than the base?
The picture above shows one of the joint's pinned and keyed. You also don't need to get this dramatic with it - just enough profile so the old and new interlock together. (Just roughing up the surface to expose the angular stone within the old concrete should be enough to lock the two together.)
The other thing I should point out is this spot is exactly where the front tire of my SUV is parked. Do you think with Minnesota weather and salt, etc it just eventually gave out in this area?
I'll bet that spot has some stories to tell..
If you had a salt or other chemical problem, then it would be in other parts of the floor. I'll bet that parking the car on top of a thin patch is what did it in. Thin patches don't hold up well under use.
That hole in the slab doesn't go all the way down to the gravel base currently, right? (If it does, you'll want to check for buried cash, time capsules, body parts, etc. before filling in.)
K
Kaoskido
So I am just getting back to this issue.
