Concrete Repair
BrandonV
Arizona
I have a few outdoor areas with small divots that I want to fill using a concrete repair product. I prefer to use a high-quality product (epoxy or similar).
Initially, I bought a two-part epoxy product from Rust-Oleum, which you can find here:
However, the product label states that "exterior applications must be coated with a solid color exterior coating." Is this warning only for people who plan to coat their concrete afterward, or is there a downside to using this product outdoors for general repairs?
I'm open to any suggestions for better products, as I want to avoid purchasing an excessive amount for just a couple of areas.
ConCretin
Central Maine
In general, I think you are better off using a repair product with similar properties to the substrate, which in your case would be a cementitious product. You will also get a better color and texture match. I'd recommend Silpro TDQ or Ardex CD. As with any repair, surface prep is the key so follow the mfg's directions.
