icedoc
I am in the planning stages of a new 12x16 shed to store my tractor, yard tools, and anything else that does not belong in my workshop. I want to do concrete so I won't have any realistic weight restrictions, and also so it will be long-lasting.
The site I have chosen for the shed was an existing garden that has a small concrete pad already beside it. The pad measures roughly 17'x6' and was used to store firewood by the previous owner. I would like to keep the pad and use it for storage BESIDE the new shed. The problem is that the pad is sloped, approximately 1ft drop over its length (runs parallel to the slope of the ground). I would ideally like the new slab to **** up against this pad, but I'm wondering how exactly I should go about doing this, and if it is even a good idea.
I was thinking of cutting forms on an angle and placing them on top of the pad (with lots of back bracing of course) so that there wouldn't be a large gap between the side of the new slab and the edge of the existing pad. However, since the new slab will be level, its bottom edge will nearly be exposed at the back corner. That troubles me, and I was thinking it might be a good idea to thicken the slab edge in that corner. Thoughts??
I've attached a quick rendering of the situation below. The new slab is in grey, the old pad is in blue.
