Wangstang
I need some input to verify that everything looks good to go for a pole barn slab which will be poured in two days.
Specs are 5000psi concrete minimum 5" thick, 3/8th rebar, with a 3' wide 8" deep section the entire width of the structure in the middle of the barn which could accommodate various bolt down items, such as a lift. Will be poured on top of 3-4" of #67 stone which was leveled on top of compacted/settled crush and run.
I can provide more photos if needed. It's a 30x48 pole barn that will need to be able to withstand farm tractors, a backhoe and a dump truck that will take 10 tons of capacity....i.e. this will need to be sturdier than the average home shop slab but not so over the top that you could land a 747 on the thing.
Please let me know what you think of the layout and specs.
Thanks
Wes
Thanks
Wes
