I used concrete sleeve anchors when I installed an outside step railing. A year later they are loose, and I can't retighten them. I was able to remove the old anchors and wonder how to successfully redo this railing install.
The concrete sleeve anchors supplied with the HD sourced railing are 10mm. The concrete drill bit HD sold me was 7/16" which they said is what I need and would work. I believe that is the source of the problem since 7/16" is 11.1mm and therefore the hole is probably too large for the 10mm anchor and that's why they won't tighten and stay tight.
There are four anchors in each of the two railing bases.
What suggestions do you have?
Thank you!
Mike in WI
Thank you!
Mike in WI
