concrete stain vs. dye
pancho400cid
Austin, TX
Hey all:
Not the garage but I see lots of guys have stained / dyed concrete so wanted to get some info.
I'm knee deep in a bedroom remodel. The house was built in the 50's and the concrete seems pretty dark. We have removed the accumulated decades of pain spatter and carpet glue.
Is there a a way to lighten the concrete any? Would using "light grey" dye instead of stain be a good idea?
The wife would like a light gray stained look, with a high gloss finish. I did my son's room using acid stain a few years back and it came out great. Any suggestions welcome. We are trying to do this ourselves without going to nuts. I would much prefer not grinding, etc but will listen to any input.
Below are before and after preliminary cleaning shots. Yes - I know the tile in the closet was asbestos type. Yes - It was removed and disposed of properly
LegacyIndustrial
deerfield, IL
light gray? go acetone dye. That floor might not work with acid and there is no "gray".
Email me for a color chart if you need it, for the dye.
My Old Tools
Hamrick Lake, TX
Acid stains for concrete are iffy on old floors. Grinding it helps, but you still likely won't get the results you get on new concrete. What about epoxy paint?
collmorgen
Deep East Texas
I did two bedrooms in my house. After getting the carpet up I used a buffer/sander on the floor and got everything up that I could. You WON'T get everything up but I was going for an antique look. I mopped, acid stained, neutralized, mopped and mopped and then sealed.
I think they look good but it's the look that I was going for. It's cheap.
