Concrete wall rubber sealer(outside)
ryan77
Indiana
Good morning all, I am soon to pour basement walls, and before backfill will rubber seal it, I have heard mixed reviews on Blue Max, and similar brands, anyone have good reviews or good products to point me in the direction of, thanks.
Don't spend a ton of money on fancy sealers.
DO spend the money on a dimple drain board applied over the sealer. This should run down to the bottom of the foundation. Lay your drain pipe/weeping system at that level and cover with at least 3-4' of gravel. If possible, back fill to withing about 1' of grade with gravel.
R
ryan77
Indiana
yes, I do have form a drain on both sides of the footer draining out to daylight, just want extra protection from cracks and moisture.
