Hey Everyone..
Noticed there was a small puddle of water in the light fixture for my bathroom fan. Pulled it down and it appears to be coming from the side of the fan. Went up in the attic and did not see any leak paths coming from the roof. I did feel moisture on the bottom of the vent tube coming out of the top of the fan in the attic, and only on the low spots of the vent tube where it was collecting.
I am trying to figure out if this is a ventilation issue in the attic as there are no baffles up and the blown in insulation appears to be covering all of the soffit venting. However this goes against what I understand about condensation. Water will condense on the warm side of 2 surfaces, given enough humidity. There is a joint in the vent tube where the water may be trickling out from, but there is a high spot where the drips would be unable to pass and yet there is still condensation on the bottom of the next low spot.
I'm thinking (hoping) this is just an ventilation issue. I think for 75 bucks at HD I can get the baffles I need.
