USAFpj
I live fairly close to the NC/SC/GA borders, and wanted to see about your different experiences with condensation in your shops.
My pole barn will have R6 insulation in the ceiling and walls, but no planned AC or heat. (2) 10x10 insulated doors, and (1) insulated steel man door. (3) 2x10 clear panels will be installed under the South facing eave, so that may add or subtract from inside moisture. Concrete slab as well.
What has been your experience with moisture in the SE, and before we start this build, should I be adding ridge vents, fans,...?
