ezridr60
I have a garage that is built in to a hillside. Condensation forms on the walls and I've been mulling over several ways to approach this. It would seem some sort of insulation is necessary on the walls. (Walls are concrete). What I was contemplating doing was putting a studded wall (treated 2X4's) up with foamboard insulation between the studs. Not sure if I should put some sort of a vapor barrier up before I applied drywall. Tyvek? Visqueen? I have already applied a coating on the walls to prevent water from getting in from outside, that is not the problem, nor was it ever. I did install a ceiling fan and keeping the air moving has helped tremendously. But it needs the insulation I think.
