1320stang said:
You say the porch is covered, but is it protected from the weather? I'm assuming the common wall side is a retaining wall to the house or a basement wall, correct? Is the roof flat and covered with EPDM because it has a deck over it? I'm wondering if the porch isn't protected and it's not sealed, the concrete could be absorbing the moisture and it's weeping out at the rods.
Thanks, everyone, for the thoughts and comments.
The house is basically a rectangle. Attached to the back of the house is a second rectangle, a one car garage. Above this garage is a "porch", which is really a garage sized room. Brick walls, no insulation, lots of glass, and a shed roof.
The new garage is attached to the (formerly) outside wall of the one car garage and doglegs around the back of it.
The new garage roof is a flat roof because if a peaked roof were used it would cover the windows in the porch. In addition, the plan is to eventually put a deck on the flat roof.
The flat roof is black EPDM, so in the summer the roof heats up during the day due to the sun. The new garage also heats up some inside, but the covered porch/old garage stay relatively cool. The ceiling of the old garage is the floor of the porch and is concrete - that's the concrete the threaded rods in the new garage are epoxied into.
So it seems to be that the cooler concrete may be cooling the rods, resulting in condensation at night when the garage starts to cool off.
It's possible that moisture in the construction lumber is providing the moisture for the condensation, but it has been up a year now so I would have thought it would have dried out by now.
Thanks.
