pamike
I recently installed a Condensing Modulating Gas Boiler for my new radiant floor heat. I have a few questions for the experts.
-I turned down the max BTU output on my boiler because I was having temp overshoot. How does the boiler limit the max btu? Is the boiler still efficient when running at less than max btu?
-I don't have a floor drain close to the boiler. Any pointers on what to do with the condensate line? It produces a lot of liquid
-Can someone explain how the outside temp sensor changes the boiler operation. Does it not fire the water as hot? Or not as fast?? The boiler hits the temp point, it appears, no matter what the temp is outside
Thanks!
Thanks!
